Hi,
I want to convert a WAV with 48KHz to MP2 with 224kbit and 44KHz.
I tried using BeSweet with tooLame but everytime I try to start the screen flashed up and then I see BeSweet again and nothing happened.
With the tooLame GUI it's the same, but there I get an error which says: "3057: Variable could not be converted to a valid number" y=optSFRQ*2352/44.1
WinBatch 32 2000C
WIL Version: 3.0cbv
I need help, because I can't convert DivX to SVCD with sound without this. Cinema Craft Encoder produces just empty MP2-files...![]()
does your wav play and sound ok?Originally Posted by fabrice1979
you used besweet--the gui?
is your audio maybe ac3?
open your divx in virtual dub, and under file-->file properties
what does it say for audio codec?
if it's ac3, then change the file extension to .ac3, and use headac3he to convert to .mp2
--if none of the above is useful or accurate, provide more specifics about your file, and what you didwhat are you askin' me for...
I'm an idiot! -
I have TMPGEnc Plus 2.58 and direct sound-conversion was disabled since 2.57. But it is still possible, but I haven't found out till now!!!
Ok, I did some clicks more and found out how to convert!!
I set tooLame as external decoder, so I think I get good quality files. Thx to all of you fellas!!!
I don't have 2.58, but it works up to and including 2.57. And the results are good even without the external decoder, if you experience any problems. 8)
Ok, I finally found out how to do it!!!
Great result!!! 8)
Now it's time to split the movie, but now I know how to do this!!
Thx 2 all of u!!!!
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 14:47 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 15:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53
