I have downloaded an AVI and its properties do not show what CODEC is used <unknown>
The clip plays in media player under XP but no sound or video.
The filename starts [PZ] <-- does this indicate a CODEC that I don't know of.
I've got DIVX, TPG and M$ MPG4 installed but these dont open it.
Any ideas?
Pete
try looking at the AVI file with a hex editor.. paying specific attention to the first few hundred bytes (or so).. usually you'll see the string "vids" followed by a four byte code for the appropriate codec that is needed. for example: "vidsMP42" or "vidsDIVX".. actually there are two FourCC codes in an
AVI file and they dont always match up.. (why, anybody?)..
or, instead of a hex editor you can use this little program called FourCC Code Changer to view an AVI's codec.
http://www.inmatrix.com/files/avic_download.shtml
then you'll know which codec you'll need to download and install. read more over here:
http://www.moviecodec.com/identifycodec/avi.shtml
-s. -
i think the FourCC Code Changer is the better option than the hex editor.
Where I walk, I walk alone. Where I fight, I fight alone.
codec
By natty in forum Newbie / General discussionsReplies: 22Last Post: 3rd Apr 2011, 13:42 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Re-Codec
By Casper_H in forum AudioReplies: 1Last Post: 21st Feb 2008, 08:10
