How to get a divx .avi file into a .mov? I can open the .avi file and play it in quicktime. Is it sufficient to just save it out of quicktime?
I have tried the Quicktime export to mpeg2 several times but it always hangs at some point.
ffmpegx seems to work fine but I am confused what settings to use. I want to create SVCD images.
I set the bit rate calculator to pick the rate. I am a little confused about the Video size. Most movies I have are letter box, 16:9. When I use the preset in ffmpegx "mov to SVCD PAL" the image is sqeezed horizontally. Do I then use SVCD 16:9 PAL or the regular 16:9 or is there something I am missing here?
Also, what is the difference between the setting for split in the mpeg 2 options and the split into chunks in the post processing? Do they both need to be set? I realize this function is not working yet but I would like to know for the future.
Results 1 to 1 of 1
A ffmpegX's problem about setting the audio bitrate
By lzero1319 in forum ffmpegX general discussionReplies: 1Last Post: 7th Apr 2012, 08:44 -
MOV to MPEG-1 with ffmpegX on Mac; doesn't play on PC
By mopkba12345 in forum Video ConversionReplies: 1Last Post: 20th Feb 2008, 10:52 -
FFMPEGX problems- MOV to AVI
By ker-plop in forum MacReplies: 8Last Post: 30th Oct 2007, 11:43 -
(some) MOV's not encoding to MP4 on ffmpegX
By DarkPhoenix77 in forum MacReplies: 2Last Post: 6th Oct 2007, 23:35 -
.MOV to VIDEO_TS How? [ffmpegX] [DVD2ONEX]
By bonespur in forum MacReplies: 5Last Post: 26th Jul 2007, 08:48
