  1. Hi
    ok - such a stupid question I should probably have put it in the newbie section, but here goes...!
    I've encoded my captured DV video using CCE, outputting the files as mpg. How the hell do I burn this now as a dvd that my standalone will recognise? I've got a pioneer A04....
    I tried using Nero and burning the file onto the DV-R using the UDF format....it will play on my PC but not on my standalone DVD player . I've read the other posts in here which says you need the VBO files etc and then create the _TS directories. All I have is the mpg file that CCE encoded - is there another step I am missing to produce these files from my mpg - or am I just burning my mpg file wrong??!!
    Any help is appreciated - I'm quickly running out of expensive DVD-R's!!!
    Thanks.
    You must author it as dvd, use any dvd authoring tool
    www.vcdhelp.com/author#dvd
    www.vcdhelp.com/tools#dvdburn
