I plan to upgrade my old Sony desktop PII 350, 320 MB RAM. I do occasional video encoding and it takes forever. Encoding a movie can take 15-45 hours depending on the quality desired.
I'm looking at the new emachines T2200:
L7VMM2 Motherboard (266 FSB); Athlon XP 2200+; VIA KM266 Chipset; 512 MB DDR RAM (PC2100); S3 SavagePro DDR Integrated Video (AGP video card upgradeable); 100 GB (7200 rpm w/2 MB) HDD; 40x12x48 CR-RW; 16x DVD; 56k V.92 SmartLink Fax Modem; 10/100 Integrated Ethernet; 6 USB 2.0 & 3 Firewire ports; Win XP, Power DVD 4, etc.
All for $750. I know emachines is not Sony, Dell, IBM, HP Gateway, etc. but comparable computers from those guys are several hundred more, if not double. Any opinions?
I've had my first emachines PC for more than 2 years now, never had any hicups. That made me buy another emachines about 6months ago.
I used to have one e-machine work okay just one samll prob. about power supply. Make sure there is a AGP slot for your new video capture card in this one.
Quick Advice on how I should go about getting my vhs onto my computer
By Teebo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2012, 00:07 -
Building a new computer and need some advice.
By ingeborgdot in forum Media Center PC / MediaCentersReplies: 79Last Post: 11th Dec 2011, 12:00 -
Need a new computer.(Need Advice)
By hellfire45 in forum ComputerReplies: 10Last Post: 14th Sep 2010, 17:40 -
Computer upgrade Advice...
By helper in forum ComputerReplies: 24Last Post: 31st Jul 2009, 12:13 -
Advice on new Computer Purchase
By wiseant in forum ComputerReplies: 12Last Post: 17th May 2008, 03:56
