I have a Sony TRV320 Digital8. I transferred some video information with MovieXone via 1394. I can't open the transferred file with VirtualDub - error says "Couldn't locate decompressor for format 'dvsd' (unknown)". I used the program GSpot to try to identify the file, GSpot says the video is
FourCC dvsd
Codec Sony Digital Video (DV)
Vendor Sony
Status COdec NOT Installed
Aspect 720x480 (1.500:1)
I have reasonable faith in this information - the sequence was identified as 9 seconds and that is what the length is.
So, is there a Sony codec I can find and download? The Sony web page was not a lot of help. One post had a kinda simular problem - suggested fix was to use a Panasonic codec - but no posts were listed after that on results.
My goal is to make a GOOD quality SVCD of my home movies. I've made plenty of poor quality ones so far.
Thanks for reading this post.
You need a VFW (video for windows) codec. Try
http://www.kmstudio.com.ua/index.htm?http://www.kmstudio.com.ua/video/codecs.htm.
I use the Panasonic one with Vdub, but that doesn't mean that the others won't also work. If I were you, I would download them allHope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Thanks for the post. The first link is in Russian, comrade. But the 2nd link was VERY helpful.
Sony Digital Video Codec
By AnchorMan in forum Software PlayingReplies: 19Last Post: 20th Mar 2024, 05:17 -
Sony Vegas or Editing programs
By nextoss in forum EditingReplies: 2Last Post: 13th Jan 2010, 14:00 -
mp3 only opens by Sony Sound Forge if it's opened / saved in other programs
By c627627 in forum AudioReplies: 7Last Post: 16th Apr 2009, 22:30 -
SonY vegas 8, codec missing
By connect in forum EditingReplies: 8Last Post: 25th May 2008, 07:58 -
MPG file from Sony P7 freezes in WMP and editing programs
By jlehrer in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2007, 09:34
