Vcd's have not been a problem on this machine. But I keep getting CDDA when trying to play svcd's made on tmpgnec. I have the 1100w ending in E05 on a yellow sticker, with the vcd/cd L E D light. iS NERO the way to go? thanks in advance......![]()
i also have a 1100W and i have one with the white kodak sticker on the box and the CD/VCD LED light on it and it plays VCDs and SVCDs fine but wont play xVCDs at all cause i think its the 512K version. i heard newer versions of the 1100W will not play VCDs or SVCDs at all.
Guest
i have the same machine and it plays both vcd and svcd just fine. i only tested one vcd though, but have tried atleast 30 svcds. what is it doing? or not doing rather! i mean can you get a menu or anything coming up? what do you use to burn?
-heidi h. -
I don't know if the region free hack has anything to do with fomat compatibility, but I have two apex 1100w 512k that can play VCD, XVCD and SVCD without any problems. I encode using TMPEGenc and burn with Nero. I did not test the units before using the hack, so I don't know if they could play those formats before.
P.S. The units were bought this year 5 months apart and in different cities
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 11:05 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 14:16 -
The secret life of the penguins
By Midzuki in forum Off topicReplies: 1Last Post: 29th Jul 2008, 08:02 -
cannot copy National Treasure 2 Secret Book
By jennybean1 in forum DVD RippingReplies: 13Last Post: 21st May 2008, 22:15
