hi just want to know if i can convert my avi(640X272) to a widescreen vcd. all i can convert it to is normal size (352X240) and it looks stretched. not very good. is there any method of converting it to 640x272 to make it look widescreen? thanks.
frisco.
Use TMPGEnc, but make sure the output is correct.
Settings > Advanced > Clip Frame > Arrange method
I sent you to that area, as you can experiment with cropping, but the default setting should be "Full screen > Keep aspect ratio" this will set the output to have "Black borders" top and bottom, which you can zoom out on a widescreen TV.
Maintain aspect ratio to avoid loosing left and right of the picture, or stretching screen.
This is normaly a default setting..
Philips Playback problems with widecreen formats
By ahhaa in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Oct 2009, 13:24 -
Convert avi to 16:9 widescreen
By sknoxxx in forum MacReplies: 4Last Post: 28th Aug 2009, 20:50 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
