Hey..i own a dvd-rom reader/player for my computer..and when i put any cd in it..the light near the word "busy" just blinks.and rejects the cd...i know this has to be software related though... dont know the name of my dvd-rom player at the moment..any program that can detect the name somehow?...really need help... dvd-rom is my new reader.and i cant copy cds from reader to burner anymore..help! plz
EDIT.5):Your IDE cable could be fried.I go through at least 2 a year.
1)go to http://www.adaptec.comand d/l "aspicheck"run it
and see if it detects any conflicts,if so d/l the latest aspilayer I think it
is 4.71.
2)If that doesn't work try "forceaspi"located in Tools.
3)Your DVD-ROM is dead,put it to rest,say a prayer....AND BUY A NEW
ONE. -
So as soon as you put any CD in the drive, it flashes and ejects the disc?
Try doing this from a DOS prompt (either using a boot disk or before Windows boots up, you can hit the pause/break button at the top right of your keyboard while your BIOS is initializing) This will tell you for sure whether or not Windows is causing this problem or not. I have a sinking feeling that your drive itself may be screwed up.
Now if it just won't READ the disc, it may be something else, such as a dirty laser lense (get a drive cleaning disc) or a software problem. You can determine if it is the lens or Windows keeping the drive from reading the disc by taking your WIndows CD and trying to boot from it. To do this, make sure that your computer's BIOS is set up to use the DVDROM (the BIOS will most likely still call it a CDROM) as one of your boot devices, then just wait for it to boot to the Windows setup screen (WIndows 98) or to ask you to press any key to boot from the disk (Windows 2000, XP).
If you need more detailed advice, let me know
Prospero
EDIT: First of all, what EXACLTY happens when you put a CD-ROM (or DVD for tahat matter) in the drive? -
hmm.i'm not positive but it might have been a option i checked in powerdvd...i doubt its a bad laser..since nothing physically really happened.and the drive isnt that old... i ran the aspi checker..and it said my aspi wasnt properly installed.... but i use nero anyways.. also my drive info is this: MT1316B BDV212B 0.36 i dont know where i could get software..would fireware help?..(if i could find it)
DVD Rom speed problem
By dafoe in forum DVD & Blu-ray WritersReplies: 8Last Post: 26th May 2010, 11:06 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
Problem reading media with LG RH4820v
By d1n1s in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jul 2008, 14:43 -
dvd rom problem
By ieh4f in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2008, 02:49 -
problem reading some discs
By nick6878 in forum DVD RippingReplies: 5Last Post: 3rd Jan 2008, 10:25
