When making a svcd do you people put around 48 mins on each cd & still have great quality??? or what do you people put on each cd?
thanx curious =)
that's about average. for best quality(compared to worst) i'll put a 60 minute movie on two cds. i'd rather get up in 30minutes to change cds with good quality, than get up in 2 minutes to "get rid" of a poor quality encode.
Where I walk, I walk alone. Where I fight, I fight alone. -
I put 60 mins max on one svcd for great quality. Here's the bitrate settings I use. http://www.mrbass.org/dvd2svcd/svcd/
I think the amount you put on one CD is determined by a number of factor, but many would agree 60 minutes per CD is probably about as far as you should go. Some of the factors that you should consider are:
- if the source is film or video, at the same bitrate 23.976 fps film has about 20% more bits per frame then a 29.976 fps video
- interlace or progressive. Interlace material requires more bits to make it look good
- fullscreen or letterbox. If you're going to letterbox a movie it'll be easier to encode since about 30-40% of the screen is the black bars
- type of movie. Action movie require more bits to encode well then a talkie. Animated and especially Japanese Anime are the hardest to encode well.
Also, use a multipass VBR (3 or 4 passes) when you encode for more optimum results.
-LeeBear
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
