I am wondering why it takes sooo long to convert a avi to vcd after I have run the decopress.exe to uncompress the audio.
In the past I was able to convert an mpeg to vcd format in a very short time with tmpgenc. Today it is taking along time like close to 5 hrs and I have a pretty fast machine with lotsa ram, 512 pc 2700 and a AMD XP1600 (1.43 ghz) running on an Epox board.
The file is 871,016KB pcm.avi. I am guessing this is the prob as in avi format with compressed audio it is only 210,399 KB.
Is there any other program that will convert a pcm.avi file faster??
The Ghoul
If you were getting better results with TMPGEnc, then why dont you use it again ?In the past I was able to convert an mpeg to vcd format in a very short time with tmpgenc
tmpgenc does not convert avi to a vcd ready mpeg. You have to use avi2vcd then you can burn the mpeg for a vcd
I was just wondering if the conversion process can be shortened. Below is my info after converting a 200 meg file from avi to mpeg format
Operating System: Windows XP
Version: 5.1
Build Number: 2600
CSD Version: Service Pack 1
DirectX Version: 8.1 (or later)
CPU Vendor: AMD
Model: Athalon or Duron
MMX Capable: Yes, SSE Capable: Yes, OS SSE Capable: Yes
Speed: 1403 MHz (approximate)
Number of processors: 1
Installed Memory: 512 MB (aprox)
Source file: C:\Movies\(smr)red_dragon-ts(1of2)_pcm.avi
Source file is 850 Mb
Source File Details:
DirectShow DETAILS:
Frames per second: 20.000000
Length: 71951 Frames
Duration: 59 minutes, 57 seconds
FilterGraph: Microsoft MPEG-4 Video Decompressor : AVI Splitter : Source :
INDIVIDUAL FRAME DETAILS:
Width: 352
Height: 176
Bit depth: 32
AUDIO DETAILS:
Format tag: 1
Channels: 2
Samples Per Second: 48000
Bits per sample: 16
Average Bytes Per Second: 192000
Sucessfully opened file with DirectShow API!
VFW DETAILS:
ERROR: VFW Could not retrieve a video frame to determine details
ERROR: Could not open source file to validate parameters.
Could not open file with Video-For-Windows API!
Using DirectShow API for file access.
Target Format is NTSC.
Total frames at target rate: 107818
Available space on target drive C:\Movies\ = 38123 Mb
Begining Target file: C:\Movies\(smr)red_dragon-ts(1of2)_pcm.mpg
Mux: S:269847, V:205834, A:44201, P:19812, Min:-13114, Max:4790, TPP:19
Mux: p[0]:35411, p[1]:8187
Prefetch missed: 1
Repeated frames saved: 35868
Encode duration: 7 hours, 2 minutes, 6 seconds
Frames per second: 4.257167 -
On what planet? Load the VCD template and encode. 100% compatible VCD output.Originally Posted by the ghoul
Oh, that was a lot to read sorry... Well I don't know about XP and TMPGEnc, I never use XP anymore.Originally Posted by the ghoul
When you download a AVI, it must be scanned for junk frames in Vdub, and another copy saved if it finds any. At the same time Vdub will warn if there are any other problems like VBR, so as to warn you not to mess with the AVI unless you de-compress it, TMPGEnc handle VBR files just fine, so long as there are no other problems...
However....
If you load a PAL/NTSC VCD template, the output mpeg is going to be correct for your DVD player.
If there are no filters used "(smr)red_dragon-ts(1of2)_pcm.avi " at "Duration: 59 minutes, 57 seconds" should not be taking the time you quote.
Its difficult to compare one AVI to the next, most of the AVI's I convert only take about 1.5 hours with most converting in real time or slightly less
If you start changing settings like 2 pass, colour correction etc, and that time can double.
"Frames per second: 4.257167" ??????? what's up ? that is very very slow, does this happen often or is it just this file ?
Most of the programs are about the same as TMPGEnc, some are a little faster at times, but on average about the same.
Example, converting a VOB file in DvdX to mpeg 1 VCD is about the same as it would take TMPGEnc.
There is no big improvements with any of the other programs, sometimes people quote another, only to find the next AVI it converts it takes more time.
I'm not a fan of XP, or AMD but what you quote sounds very slow, and does sound like there is sometime wrong. -
use dvd2svcd with mpeg1 output selected and tmpgenc. as long as you don.t have an invalid framerate, you'll be find with just a few steps on the initial setup-
1- select mpeg1 output
2- adjust the bitrate to compliant vcd standards
3- select a title picture, disk name, etc.
4- " we don't need no water , let that ****** ****** burn"Where I walk, I walk alone. Where I fight, I fight alone. -
On the contratry! TMPGEnc outputs beautifully VCD compliant MPEG streams. And (if you're brave) even more beautiful non compliant streams, that at least my DVD plays with value added experience. av12vcd is simplesimplesimple - Use TMPGEnc!
/Mats
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
