any ideas on why tmpgenc will load mpeg2 video, but not the audio?
I have been running into this same problem recently and I can't figure out why. When I Merge shorter mpg files into one large on and then play it back after the encode, it will show the video and no sound at all even though the original files all have sound. I have noticed though that after I encode them and then burn them to a svcd using nero, it will reencode them and my audio will play again.
i did figure it out. you have to de-muliplex video, then use the original file for "video" and you use the audio file from de-multiplexing; for "audio". i don`t understand why you have to do that, but it works. audio was in sync with video, worked fine.
losing audio when loading into vid editor..
By krohm in forum EditingReplies: 26Last Post: 24th May 2010, 08:41 -
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 19:52 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 06:12 -
Sync Problem when loading into Vdub MPEG2
By ebayer077 in forum Video ConversionReplies: 0Last Post: 2nd Aug 2007, 13:55 -
Problem loading AC-3 audio (inside MPEG) in Premiere
By irving in forum EditingReplies: 2Last Post: 23rd May 2007, 09:25
