Can the Apex 600 play svcd's recorded with VBR (variable bit rate), I know it works with CBR (constant bit rate), An answer would be greatly appreciated![]()
I have never heard of any svcd compliant dvd player that cannot play vbr encoded SVCDS, especially if it can play CBR encoded ones. VBR is supported in the standard so if any dvd player that claims to support SVCDS cannot play it then it is defective.
I have this player and I can tell you from experience that it will definitely play VBR encoded SVCDS. -
thanks for the quick reply..........I guess I'm screwed because my apex 600 will not play svcd's recorded with vbr....it has no problem with ones recorded with cbr (its actually the same clip re-recorded with cbr).....it also stopped playing the only DVD-R that i have, any relation and is there anything I could do to fix.......
TV Wonder 600 and TV Wonder HD 600, is there any real difference?
By jedi55 in forum Capturing and VCRReplies: 3Last Post: 20th Mar 2011, 21:53 -
WHICH LAPTOP for around $600
By blinky88 in forum ComputerReplies: 16Last Post: 18th Mar 2011, 03:23 -
Biostek XS-600 help
By binkx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Oct 2008, 08:46 -
Apex AD1250X Owners?
By nemesys23 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 17:36 -
Which Camcorder under $600
By chesnex in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st Oct 2007, 03:32
