If I want a capture card that can capture to SVCD compliant files in real-time, should I look for a real-time MPEG1 or real-time MPEG2 capture card ? Any capture card recommendations ? Is the quality of the SVCD captured real-time superb or should I prefer the old AVI to SVCD encoding if I want superb quality ?
Thx in advance for your suggestions.
ATI AIW 128 / 128 Pro / Radeon can do SVCD in realtime, but requires a re-mux, which takes about 10 min/ hour of video. you need at least a P3 700 or Athlon 750 for top quality. from a vhs source, the AVI encode method looks better, but from clips i've done from a dvd source it's better in some respects (the artifacts are like JPG 'mosquitos' instead of macroblocking with TMPG)
So, let me get that straight :
1) The capture cards that can do real-time SVCD encoding are listed as hardware MPEG or MPEG-2 capture cards ?
2) Which card is better (in terms of quality) in real-time SVCD capturing ? DV500+ or Dazzle II ?
<font size=-1>[ This Message was edited by: iparout on 2001-08-18 02:30:47 ]</font> -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I've found that Mpeg2vcr (Womble) will demux an 800 meg file in less than 90 seconds. It will remux nearly as fast. It's very very fast when compared to TMPG. -
Ocen again the ATI AIW is not real-time hardware it real-time software using ligos codec
DV500+ has no MPEG hardware but if want product from Pinnacle that has MPEG hardware support you need DC1000, DC1000DV, DC2000DV, I think this one also has real-time MPEG hardware supper "Pro-ONE" but I don't know sure been it very new product.
<font size=-1>[ This Message was edited by: SHS on 2001-08-18 07:07:17 ]</font> -
I think that DV 500+ enables real-time MPEG 2 hardware capturing up to 6000 kbps. Look at the capture card list for that. Something I don't understand is how DV 500+ can capture DV although not using Firewire. Does the PCI slot enables high data transfers required by the DV format ?
BTW, does anyone know any decent real-time SVCD capture cards with good quality capturing ? (I've heard that the Dazzle DVC II gives horrible quality when using the SVCD template.)
<font size=-1>[ This Message was edited by: iparout on 2001-08-18 09:11:30 ]</font> -
No DV 500+ enables real-time DV only.
It work same as TV card dose the only diff is there no support for tuner so chip it using a lot smaller only support s-video/composite.
DV 500+ using Premiere with the ligos export formats codec.
http://www.videoguys.com/dv500plusreview.html
http://www.videoguys.com/board/?topic=topic1&msg=284
Real-time analog to DV capture - what is the right device to use?
By Serge_KB in forum Capturing and VCRReplies: 16Last Post: 24th Apr 2012, 13:33 -
Real time video capture/display software?
By TheDunk in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2012, 23:16 -
How to capture real-time video from my camcorder onto my PC
By seanhalley in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2011, 05:37 -
FlYDS capture REAL-TIME MPEG-2
By goal in forum Capturing and VCRReplies: 3Last Post: 27th Feb 2008, 05:08 -
Capture in Mpg Real Time-Best settings?
By themaster1 in forum Video ConversionReplies: 3Last Post: 21st Jun 2007, 22:01
