is there an easy way to split a mpeg file hat is too big to fit on cd-rom. i've tried some from downloads.com but they dont split large video files. i have one file that is 1.5g large that i need to split in three for example.![]()
Try TMPGenc - Goto Menu options Mpeg Utils and then use cut/merge tab for splitting mpeg files.
GangaPrasad -
if your file is 1.5 you shouldnt need to split it in 3, just 2.
2 files would do just fine if you making a vcd or svcd. you can put up to 800mb on a cdr when doing a vcd or svcd.
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
Splitting Mpeg-2 DVD files..
By Veepa in forum EditingReplies: 2Last Post: 11th Mar 2010, 05:25 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 13:24 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 19:18
