Have recently bought a spindle of 90 mins cd-r why wont nero reconise them . It is still saying that am using 80mins , how do i get it to reconize 90 mins plz
Start NERO up, goto FILE/PREFERENCES, look in the General window that will popup for the red marker, in that change the min so that it says 85.
Also in the same window, UNCHECK the "CHECK FOR CORRECT DISC FORMAT BEFORE BURNING".
Now click on the EXPERTS FEATURES TAB, in there CHECK Enable Overburn and in the Maximum CD Length window put the time to look like this.....> 99 : 59 : 00, then just click OK and shutdown Nero.
Nero should now Burn onto 90mins CDR's without any hassle.
Hope That Helps -
Nero will burn a 90min.cd-r,it just states "80min."due to red book
specs.
I looked at your comp.details:are you sure your writer supports
overburning?If not you can damage it by going over 84min.
Playing a clip every 15 mins
By christian_j in forum Video Streaming DownloadingReplies: 0Last Post: 6th May 2010, 13:30 -
MKV, 1:37 long, audio always comes out 44 mins only..
By TheGlow in forum Video ConversionReplies: 6Last Post: 20th Apr 2009, 16:45 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19 -
Youtube 10 mins 59 secs?
By nam207 in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 23:24 -
MPEG_Streamclip - Only Exporting 1.33 mins ?
By 12Quidkidinnit in forum Video ConversionReplies: 0Last Post: 23rd Jul 2007, 08:26
