ok guys i need help purchasing a video card
my firts question is should i buy the ati all in wonder card or sould i buy a video card + a tv tuner card
what do u guys recommend using windows xp pro thanks
And You want to use it for what? There is no "the best" solution, but are "optimal" ones. Everything is based on requirements/needs. What will You write ((X)(S)VCD/DVD)? Where do You capture from? What do You capture? How much do You want to edit? What's Your budget? It is harder than buying a car, You know!
Ok first thing i would like to do is put my vhs tapes on a cd
second be able to watch let s say a football game while I am browsing the internet and also be able to watch a dvd movie while I am recording it on my pc -
So, basically any TV card with composite in will do (including AIW) until You don't want to make DVDs. Macrovision insensitive ones will be prefferable. About this DVD recording I didn't understand
You might consider the WinTV PVR 250 from Hauppauge www.hauppauge.com - is this kinda what you are looking for?
Panasonic DMR-ES45VS, keep those discs a burnin' -
ok let me try to explaing what i mean by dvd recording
i was thinking that since somevideo card comes with tv in & out maybe it is possible for me to play a dvd movie on my dvd player at home and capture the video from the tv using my tv in connection from the video card
But the main thing is i have an old 32 mb card i want to upgrade and i also want a tv tuner one i can browse the internet and wath tv at the same time , should i just get the ati all in wonder 8500 128mb or by the ati 8500+the tv tuner thanks
YAAI help needed
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2011, 06:18 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 11:33 -
Help Needed with AVSINPaint
By tribal1965 in forum EditingReplies: 18Last Post: 6th Aug 2010, 20:47 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
