I have read through as much of the advice as I can in the time that I have and have tried various things, but can I get my converted mpeg to SVCD title to play on my stand alone DVD player? No!
Here's the way I went about it:
1) Converted and enccoed the file to SVCD using Nero 5.5.9.0
2) Applied the "VCD header trick" using TMPGEnc-2
3) Burned the file using Nero Express and selected SVCD
Now, it plays on my computer, although the quality of the picture is pretty bad, but it does not play on my DVD player. I put the CD in the machine, it registers it as a "CD" and not "SVCD" as I thought it would, it allowed me to play it, but nothing! No sound, nopicture, but the machine is playing ita nd counting up the minutes that pass.
Can someone suggest another way, or correct what I am doing wrong?
Many thanks in advance.
Mazo
First, item 1, how do you convert and encode to mpg using nero? or do you actually mean using Tmpgenc?
Second, some player won't play SVCD, or SVCD with header trick, so what is your model of standalone DVD player? -
first of all, the vcd header trick doesn't work for all players.Originally Posted by Mazo
second of all, did you check the compatibility of your player?
http://www.vcdhelp.com/dvdplayers
@tom28--Nero can encode, it just does a piss poor job.
@Mazo: try following one of these guides instead:
http://www.vcdhelp.com/tmpgencsvcd.htm
http://www.vcdhelp.com/avitovcdfoolproofusingcce/what are you askin' me for...
I'm an idiot! -
Sorry, I didn't explain properly.
First of all I encoded the file using tmpgenc, not Nero as I first suggested. Doh!
I then applied the header trick, and then burned the file using Nero express wizard. I told the wizard I wanted to make an SVCD and it went about it process of encoding the file and then burning it to disk. Could this be what the problem is? The fact the it re-encodes the file before burning it?
FYI - My DVD player is a Pioneer DV-626. It plays VCD's no problem.
Thanks for you help.
Mazo -
Leting to re-encode by nero introduces problem with quality, not playability. To not let re-encode You must supply file muxed properly for SVCD (or burn XSVCD).
Another thing and more important : Your player (like most) is reported NOT to play SVCDs. -
I use the encoder trick also for my svcd mpeg2 files. and i use nero to burn.
When you burn in nero dont select to make an svcd disc. that is why you put the header trick on the file. to make it a vcd when its actually and svcd.
Select in nero to make a vcd. uncheck the make compliant disk box, or if you use the wizard it will tell you that the file is not compliant, select the option to make non compliant vcd.
now you will have a vcd that will play in your dvd player , but it will in fact actually be playing an mpeg2 svcd file.
Thanks very much for all your replies. I'll let you know how I get on.
M
Easy Question..Make duplicate of movie DVD
By WareISChris36 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2011, 15:43 -
Stream from friend to friend program easy to make?
By Homebrew77 in forum Video Streaming DownloadingReplies: 0Last Post: 30th May 2011, 07:27 -
Any easy tool to make a DVD photos slideshow with the background?
By coody in forum Authoring (DVD)Replies: 9Last Post: 27th Sep 2008, 15:34 -
Can you guys look at my commercial?
By dogmaratt in forum Off topicReplies: 10Last Post: 17th Feb 2008, 11:42 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 19:31
