I am trying to add multi audio tracks to SVCD Mpeg2 file. Do you know which software do this other than I-AUTHOR?.
Author your video stream and two audio streams separately. You can then multiplex them all together in I-Author, bbmpeg, or TMPGenc's multiplex option in mpeg tools (not simple multiplex.)
Originally Posted by adam
Are these plexed audiostreams seperatly available on svcd later? -
Yes you encode each stream separately. You make 1 video only stream, and 2 audio only streams and then you multiplex all three together.
When you play the SVCD you can use the Audio button on your remote to toggle between the different audio tracks, or some dvd players let you set the audio stream in the player's main menu. -
Okay, i have another question. I have two parts and donīt know if tmpeg can handle these two audio streams when joining?
Does anyone know that? -
Originally Posted by zedriq
Actually the first audio stream is shown, but no second one?!
And after multiplexing the first parts the 2 audio stream arenīt shown, too.
What did i wrong? -
Tmpeg always tells me that the stream causes an 65xxxsecs overflow after multiplexing all 3 streams (1 video & the 2 audios) together...
Why does this not work?
The original avi has a resolution of 640x272 pixels and 23,976fps.
Do i need to convert this one with the same settings? Think not. Please help..
These are my settings:
MPEG-2 format, 25fps, 480x576pixels, 2520Kb/s CBR, PAL
Please, if anyone knows an answer then reply...
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 09:40 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01 -
MPEG2-TS (multiple audio tracks) to DivX/XviD
By cecco in forum Authoring (DVD)Replies: 3Last Post: 31st Jan 2008, 09:05
