I've got this MPG file, which I can't open in Virtualdub or TMPGEnc. I've get a synchronisation error in virtualDub, and a cannot open or unsupported error in TMPGEnc.
I can open the file in DVD2AVI, and see it, but I can't save it like it's says in the convert part of VCDhelp/convert.
PLZ help TIA![]()
Is it mpeg-1 or mpeg-2?
Virtualdub will not open mpeg-2 files.
TmpGenc (most recent versions) require one of a small number of specific mpeg-2 codecs be installed in order to open mpeg-2 files. Use search or look at TmpGenc site to find which ones are supported, (PowerDVD I think is one).
Hope this helps -
Originally Posted by John_do
If your using a Free TMPGEnc V 2.55 or less, you can load it provided your 30 days are not up, Any newer versions, or the TMPGEnc Plus 2.58 will require 1 of 3 supported Mpeg 2 filters, the most popular provided with Power DVD 4.
For Free TMPGEnc
http://www.digital-digest.com/dvd/downloads/encoding_plugin.html
Power DVD 4
http://www.gocyberlink.com/english/download/dl_file.jsp?dl_id=1
Or search Kazaa
Also make sure you check this in TMPGEnc
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
vdub avi file opening problem
By naveenkrish in forum EditingReplies: 3Last Post: 8th Jun 2010, 11:54 -
Xvid4PSP .mkv file opening problem
By hibbs in forum Video ConversionReplies: 2Last Post: 23rd Mar 2010, 18:56 -
(Sound Problem) Converting karaoke Vob file to mpg/ other video type cause.
By kiangtong in forum Video ConversionReplies: 1Last Post: 23rd Jan 2010, 03:45 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 10:53
