I try to convert footage that I took from my TRV9E digital camera onto SVCD. The footage is 704*576. I use TMPGEnc to create a MPEG-2 file. I burn this file using NERO to SVCD. File becomes 480*576 PAL.
If I play the disk in my Pioneer DV-350 the image on television is vertically squeezed.
I have tried lots of settings but the result remains the same.
What am I doing wrong and what could be a solution
Peter
under advances set the input aspect ratio from 1:1 to 4:3 this should solve your problem.
Input and Output aspect ratio is 4:3 625 line PAL but I have tried with 16:9 as well which squeezes it even more.
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
720 x 576 question
By higgins327 in forum Newbie / General discussionsReplies: 24Last Post: 31st Mar 2011, 15:44 -
720 x 576 (2703kbps bitrate) AVI for Archos 704
By drstew in forum Portable VideoReplies: 10Last Post: 31st Aug 2008, 14:49 -
704 x 576 Resolution in Premiere
By Haz567_a in forum EditingReplies: 5Last Post: 23rd Jul 2008, 06:01 -
dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
By aljolson in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2008, 12:54
