hi - i have been downloading tv episodes in *.mpg format and burning them to vcd using adapec /roxio Toast 5.1 under MAC OSX. Every once in a while a downloaded mpg file will not be accepted by Toast - allthough the file properties and format seem to be exactly the same as for the other files that did work with TOAST.
Can anybody give me a hint on where the problem might be ? Should i use a different sofware to burn vcds ?
many thanks for any help
marc
Results 1 to 9 of 9
I gave up using Adaptec/Roxio products because they can only do compliant burns.
Using a combination of the following freebies,you can't go wrong (compliant or not):
Virtualdub,TMPGE and VCDEASY."Today is only yesterdays tomorrow" -
wee - i am using a mac. do these tools also exist on the macintosh platform ? thanks -
Originally Posted by tk265
ahh...thats a good question.
I don't think so....sorry"Today is only yesterdays tomorrow" -
Load TMPGEnc, select Mpeg tools > Merge&Cut > Add
Add your Mpeg, and from the drop down combo, select "MPEG 1 Video CD"
Click the edit button and make sure the full range is selected (Previous settings may be there)
Type the output name and location and click start.
This will stream another copy of the mpeg, and fix little problems like bitrate being slightly out
1150 could be 1150,XXXX etc -
King - i am not sure if this tmpgenc tool is available on the macintosh platform. if yes - can you tell me where to find it ? many thanks for your kind help !
Use MissingMPEGTools to author your MPEGs into .IMG tracks and burn them in Toast using CD-ROM XA mode.
AntnyMD - thanks alot for the tip. I will try that tonight and hopefully it will work
many thanks !
thats why we have a MAC topic I guess
Converting an AVI file in Toast PROBLEM!!!!!!!!!!!
By thasco in forum MacReplies: 10Last Post: 14th Dec 2010, 10:44 -
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 21:58 -
converting mpg file to MP4
By bdaul in forum ffmpegX general discussionReplies: 6Last Post: 16th Jul 2008, 16:54 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 09:03
