I've been successfully creating PAL compliant SVCDs with Smartripper, DVD2AVI, TMPGENC and Toolame and would like to add a second audio track to the so created SVCD.
Can anybody help?
If you prefer to use dvd2avi to get your wav file than just make a second project file with the second audio track selected. Under the audio tab set it to the appropriate track. If you want to see what's what then in smartripper do stream processing on your vobs. This will show you what language and format each audio track on the dvd is, eg: dolby digital, 2.0
After you have your wav file encode to mp2 with toolame. Do this with both audio tracks, encode everything separately. Now you should have an m2v file, and two mps files.
Now just multiplex them together with either bbmpeg or TMPGenc.
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
Create an uncut composite by editing the audio track
By TRAXX-74 in forum Authoring (DVD)Replies: 3Last Post: 12th Sep 2008, 20:32 -
create pseudo stereo from mono track..
By nopk in forum RestorationReplies: 14Last Post: 8th Dec 2007, 18:31 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 09:25
