I'm confused about the distinction between encoders and videotypes. By video types, I AVI, MPEG, DIVX - vs. Intel 5.04, Cineplex, Windows MPEG-2 Type 1, and so on.
I thought, for example, AVI has a particular spec for how video and sound is encoded. You could change things within AVI - like resolution. But when I started fooling with ULead, Virtual Dub, and VCD Easy; I had to start fooling with the codec.
For example, in ULead when I capture a file from my camcorder with a firewire connection, I save as AVI *BUT* I also chose the codec. I could use any codec on my computer that ULead 'found' - like the Intel 5.04 or Windows MPEG-2 Type 1. This affected the quality of the capture - and file size.
So, where and what is AVI and why can I use an MPEG-2 codec to capture AVI? I thought if I wanted to capture and compress with MPEG-2, I saved as MPEG.
Thanks for reading this and your replies are appreciated.
Found this in a newsgroup:
AVI stands for Audio Video Interleaved. The .AVI format defines where the
computer should expect to find header information, audio data, and video
data. The data itself may be compressed/encoded in a manner unrelated to the specification of the .AVI file format.
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Confused About Video Cards
By wulf109 in forum ComputerReplies: 2Last Post: 11th Nov 2010, 10:59 -
Confused about all the different video formats
By jacatone in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2010, 08:50 -
Confused about Harware vs Software encoder
By marche in forum Capturing and VCRReplies: 6Last Post: 11th Oct 2008, 09:08
