  1. how can i turn a flash movie into vcd mpeg...........
  2. SWF2Video 1.1
    SWF2Video converts SWF to AVI including all movie clips and action scripts in the Flash movies. SWF2Video allows users to specify the dimension and the start/end frame numbers to convert. It also allows the interaction on Flash content during conversion. By setting the parameters among the compression methods installed in window system, designers can convert the flash to the video with qualities best fit to their requirements. As the program won't skip frames during conversion, the result video's quality won't be sacrificed. In this new release, SWF2Video records the audio track of the SWF file and then mixes the audio data into the output video file. By the above 2-phase processes, the program uniquely supports the audio conversion feature from flash to video. It also allow user to specify an external audio file to add to the output video.
    [Download] [Alt Download] [BUY Now] [Home Page] [Shareware] [Size: 817KB] [OS: Windows All] [Date Updated: 19/07/2002]
    got this info from here: http://www.softlandmark.com/VideoEncoder1.htm
    It is a trial, but i think you can FIX that huh...
  3. You don't need any software Just Flash and video encode software like TMPGEnc
    First export movie from flash as an avi uncompress (set resolution and framerate to what ever template you wish to use), then load that avi into TMPGEnc. If you need sound also then I'd suggest you load seperate wave file into TMPGEnc not in flash.
    Hope it help.
