[/url]http://www.vcdhelp.com/DVD2DVD-R%20bigger%20than%204500%20megs/
I did every step on the tutorial.I ripped the movie to my HH,converted the ac3 audio to wav,calculated the bitrate,encoded the movie, and then when I try to burn the movie with DVDitPE the sound was too ahead of the movie.Did I forget to do something with the sound? or
is there something else I need to do with the sound?
Any help will be greatly appreciated.
what program did u use to transcode the movie...if u used rempeg u can just remux the m2v stream back into vobs with the audio using IFOEDIT
if u used tmpg or cce u need to reauthor the streams like u were doing with dvdit
i cant answer your immediate question on why the sound was outta sync but i can give u suggestions on better methods
first, u should use a authoring program that can handle .ac3 streams
like (the easiest) spruce up. then u wouldnt need to convert to wav PLUS since an ac3 stream is more compressed than a wav file , the audio is MUCH smaller in size than a wav file, saving that extra space could go to your video stream to make the quality better
i hope this has help u in some way
copy You Tube to DVD,sound leave problems..
By gary153 in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2010, 08:33 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 15:38 -
Sound problems with dvd burn
By illyad in forum DVD RippingReplies: 1Last Post: 9th Dec 2007, 08:51 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
