In Tmpgenc, when encoding a movie as DVD (PAL), why is the resolution for MPEG 2 352 x 576? Normally a picture is wider than it is high. I am assuming that when you author it and burn it to DVD it gets changed or does the DVD player do something to the picture to make it wider when decoding it. This is not an important question or problem, I am just trying to understand the logic involved.
Thanks.
You are using the default TMPGenc dvd (pal) template? Because it should be 720x576. 352x576 is also a compliant pal resolution for DVD but it is not the full D-1 resolution that commercial dvds use.
Perhaps you accidentally adjusted the template and then saved over the old one, or maybe an incorrect template was just released with your version of TMPGenc. In any case the correct resolution for that template is 720x576, -
The version of Tmpgenc I downloaded only seems to have templates with the non standard resolutions. A. where can I get the correct templates for standard DVD, VCD and SVCD and B. can I load these templates so that they are accessible through not only the 'load' button but also in the wizard so I can batch encode multiple .avi files (I have not worked out how to do this outside of the wizard and the wizard uses the default templates).
Mixing AVCHD with SD DV-AVI, frame size & arrangement question...
By sdsumike619 in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2012, 23:18 -
A Question On How To Calculate Frame Size When Resizing Vid for DVD
By hydrophonicaudio in forum Newbie / General discussionsReplies: 13Last Post: 21st Feb 2011, 08:53 -
Dumb question, but should be easy to answer :). Re DVD Flick high quality
By cognus in forum Authoring (DVD)Replies: 10Last Post: 14th Jun 2010, 00:43 -
Dumb Question - Burning Blu-Ray movie with a standard DVD-R burner?
By toxicquack in forum Authoring (Blu-ray)Replies: 7Last Post: 18th Aug 2009, 04:59 -
Ok, here's another dumb question --- tuners in DVD recorders?
By Trollheart in forum DVD & Blu-ray RecordersReplies: 7Last Post: 7th Mar 2008, 12:28
