I have an AVI file I downloaded that was Divx 3 with AC3 audio, I extracted the audio with virtualdub and converted it to PCM wav 44100hz using AC3decode. I end up with a wav file that is 3 seconds shorter than my AVI file, Is there any way to make adjustments for this 3 second sync problem with TMPGEnc or have I made a mistake in converting the audio?![]()
try reconverting the audio, but don't create a WAV file, just click on SAVE AS AVI... I think that will solve your problem
best of luck 8)Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Have you tried encoding a sample to see whether you actually get sync errors?Is there any way to make adjustments for this 3 second sync problem with TMPGEnc or have I made a mistake in converting the audio?
I was able to solve my own problem so I figured I would tell you what I did in case anyone else has this problem. I did encode the file and the audio stated out fine but by the end it was way out of sync which makes sense because the file was 3 seconds shorter. I went back and converted the audio again using AC3decode but this time I left it as 48000hz wave instead of 44100hz and everything worked perfectly. I previously thought you had to convert to 44100hz for stereo but this is obviously not the case.
That is very strange. Resampling does not alter the length of the audio!
No its converted to 44.1Khz for use with VCD, TMPGEnc will convert AC3 and 48Khz without any problems.Originally Posted by hammerhead
Some of the DVD rip's made by programs do not always keep in sync, and drift out more and more (DvdX V2 on some VOB files) Dvdx 1.7 OK, somtimes people play the AVI's for a few min and think they are OK
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 13:27 -
stereo loss after converting from wav to ac3
By Driber in forum AudioReplies: 8Last Post: 9th Sep 2009, 02:29 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
