Hello...
This is the first time I capture from DV source.... I have some problems..
When i have got a .avi file from ScenAlyzer i get pretty good quality but very big size in mb. How do i convert it to DiVX and better quality? I tried to use virtualdub, but when i should open the .avi i got an error saying:
Couldnt locate decompressor for format 'dvsd' (unknown)
VirtualDub requires a Video For Windows (VFW) compatible codec to decompress video. Directshow codecs such as those used by Windows Media Player, are not suitable
I tried to look for a codec or something but didnt find anything. Does anyone know how to do it?![]()
And the second question, less priority: When i make a SVCD form the .avi with TMPGenc, i get like "lines" when the camera moves fast. I kind of get lines thats being messed out on the movie when somebody for example runs on the movie... why?
Thx!
beejay
1 DV is a large format - it only uses 5:1 copmpression so files will be large.
2 ViirtualDub only accepts VFW codecs - you can try and track down a Canopus decode codec - it's a VFW codec that gives much better results than the directshow MS codec.
Unless they are noise - most likely they are interlacing lines.
http://www.100fps.com has an excellent breakdown of this with lots of very nice pictures.
captured some video
By the_man_one in forum Capturing and VCRReplies: 10Last Post: 19th Aug 2011, 05:42 -
why is captured video sometimes glitchy
By janaka_k in forum Capturing and VCRReplies: 5Last Post: 16th May 2010, 08:01 -
HD captured to SD vs Recorded SD
By C_Copeland in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th May 2009, 19:19 -
Captured now edit..advice
By aussiemac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th Nov 2008, 12:52 -
Captured Video Out of Sync
By tumaz in forum RestorationReplies: 1Last Post: 9th Jan 2008, 20:55
