  1. Ok, 2 questions, #2 is more important...
    #1: Is there a way to rip sound from VOB files? I do not have the DVD, just the ripped copy of the DVD on my hard drive, and I want to take the sound out of the files.....
    #2: What does it mean if the sound for a movie (not all movies, but sometimes...example: The Rookie) has a very faint "pop! pop!" sound while the sound is playing? Is this a copyrited disk, because it happens usually with Disney or other big companies...
    #3: I have my DVD player attached to my TV through my VCR. Why is it that when i record the input (which should be the movie) onto a tape, it comes out HORRIBLE with lines and messed up sound and video?
    Thanks a lot....i know its a lot of questions, but help would be appreciated
    -Yar, matey!-
  2. Member Treebeard's Avatar
    Aug 2002
    u can get a wav file from the vob's by using DVD2AVI. What type of sound file are you trying to get?
  3. The sound file type does not matter, i can always encode it to whatever i want...ill try dvd2avi tho, thanks
    -Yar, matey!-
