Hi all,
I am having a problem with Real Magic's DVDStation on WinXP. The picture plays fine and I can link it thru to my telly fine, but there is no audio on either my TV or PC? Last time this happened it was just a case of checking/unchecking a few boxes in the Volume Control but I've tried for ages and cant get any sound, any ideas?
Thanks in advance.![]()
I'm going to assume that this is the only application having problems with sound output. I haven't used DVD station in a long time, not since I was using Windows 98, so I'm not terribly familiar with the newer versions and how they work with Windows XP. In light of this lack of knowledge on the subject, all I can tell you to do is double check all of your options, then try reinstalling the program from scratch, that is completely uninstall DVD station before installing it again; take all entries out of the registry, make sure all files are deleted off of the hard drive, etc.
Sorry I can't give oyu more specific device,
Prospero
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
annoying buzz sound while playing a DVD
By Umen Pich in forum Authoring (DVD)Replies: 7Last Post: 12th Apr 2009, 22:21 -
No sound when playing on DVD
By blue nose in forum Authoring (DVD)Replies: 6Last Post: 11th Mar 2008, 13:11 -
windows mp is not playing sound on videos (but only on one windows account)
By lightsout85 in forum Software PlayingReplies: 0Last Post: 30th Jul 2007, 15:19 -
No sound when playing in DVD player
By blizzery in forum AudioReplies: 1Last Post: 28th Jul 2007, 18:35
