i verify the codecs that i have on my computer (control panel\sounds and multimedia\hardware..etc.)
now i am looking to capture video from vhs with vdub. when i look at video\compression, not all the codecs that i have are listed (especially the one i would like to use)
1. how do i get vdub to use those codecs?
2. how do i get cce to use those codecs for encoding to mpv?
thanks for the help
Most of those codec are probably DirectShow based. Neither Vdub or CCE recognize DirectShow codec's.
Sorry -
Try grabbing the codecs from the tools section, and reinstall them. They might need a separate install, and Vdub might not recognize the ones bundled with your currrent capture/video card. Most people agree that capturing with Huffy or PicVideo is the best solution for size and quality issues. I'm personally trying with uncompressed today, to see if there's a difference between uncompressed and Huffy.
Good luck!!!!!!! -
Oh...
For capturing VDub will only show those codes that are compatible with the capture format that you have chosen.
How to add codecs to VDub?
By newtie in forum Video ConversionReplies: 3Last Post: 18th Feb 2011, 02:02 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 16:29 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52
