Can I do this? Convert my whole movie to SVCD instead of encoding "source ranges." Then break up the mpeg-2 file AFTER conversion and burn.
TMPGENC CAN CUT AN MPEG2 FILE AFTER ITS ENCODED.
GO TO FILE- MPEG TOOLS--MERGE & CUT. -
You can also use bbmpeg, there's a guide on this site under "Edit". I've heard that bbmpeg tends to do a little better than tmpgenc for cutting.
Originally Posted by sterno
but...you have to start with .mp2 and .mpa files (or demux w/TMPG) and then multiplex them, and set your max file size(795MB for 80 min. CD)
works greatwhat are you askin' me for...
I'm an idiot!
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 21:58 -
Glitch at Chapter Break in MPG/VOB
By ironorr in forum Software PlayingReplies: 0Last Post: 29th Dec 2008, 15:49 -
converting mpg file to MP4
By bdaul in forum ffmpegX general discussionReplies: 6Last Post: 16th Jul 2008, 16:54 -
Converting VOB file to MPG
By weenie02000 in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 13:58 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 09:03
