I have been trying to rip my own Peter Pan- Return to Neverland just for practice by demuxing it with Smartripper to get a m2v & ac3 file. I then rename the two files to pan.m2v & pan.ac3. There was only one English audio channel (6.1) listed. Both files were created with no problems. When I import them into SpruceUp, the m2v video file loads with no problem (after about 5 minutes), but after the audio file loads, a screen pops up that says "inconsistent bit rate in some audio frames" (or something very similar to that). Then it doesn't load the audio file. I get the same error message importing into DVDMaestro. If I multiplex in tmpgenc I can play the file in PowerDVD with no apparent problems, no sync problems. If I load the single multiplexed file into SpruceUp, it appears to load up after 8-10 minutes of importing, but never shows up on the menu. Does anyone know why the audio bit rate would be inconsistent? I demuxed with decryptor too with the same result.
Thanks for your help.
Bruce Skousen
