I'm using TMPGEnc to create VCD/XVCDs from MJPEG AVIs. From reading the forms I found some helpful info. One suggestion was to download the mainconcept codex so that TMPGEnc could open the MJPEG AVIs. I did and it worked. I also found this suggestions in the guides. If that does not work try to change the codec reader settings in TMPGEnc under Option->
Environmental settings->VFAPI plug-in and right click on the AVI VFW
and increase the priority to 1 and try open the video. We I did this I noticed that the quality of the mpegs went down (blockey). I have since reset the defaults in VFAPI. My questions is, how can I tell which codex TMPGEnc is using to encode the mpeg. I understand that TMPGEnc is one of the best encoders, if I have download another codex I'm not using TMPGEnc to the best of its ability? Why did the quality go down when the AVI VFW priority was increased ?
tks
lg
Results 1 to 1 of 1
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 18:58 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22
