Does Maestro Support ac3 sound and 16:9 ratio? I've just got spuceup sorted only to find out it doesn't support 16:9.Iv'e got dvditpe but that doesn't support ac3, I've got scenarist but they won't play on my stand alone, I am just going round in circles.
As I understand it (I have to confess I haven't done this myself yet) you can choose to create the title set on your hard drive with SpruceUp (instead of burning to the DVD directly) and then use IFOEdit to modify the aspect ratio bit in the IFOs it creates to set 16:9 instead of 4:3. Then burn the files (with something like Nero) and they should play back at 16:9.
Xesdeeni -
yes you can use spruceup and ifoedit, http://www.vcdhelp.com/forum/viewtopic.php?t=115882
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 20:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
