Having read numerous posts on audio sync issues I still cannot get this right. Heres the situation:
Captured my own DV (PAL) and edited in Premier. Then output a DV AVI which plays fine. Then convert to MPEG2 with either TMPGEnc or Ulead Video Toolbox (also plays fine), then burn to SVCD using either VCDEasy or Nero5. Now when I play this on my home player the picture is excellent - no artifacts or skips, BUT the damn audio is about half a second out.
If I use the LSX MPEG plugin for Premiere to output the MPEG2 direct from the timeline I get the same problem but slightly worse. I even tried using the Nero plugin, but that was a complete disaster.
What is it that makes audio sync so difficult on SVCD.
For the record, I can output MPEG2 for DVD onto DVD-R or RW perfectly with audio in sync.
Any tips/help greatly appreciated as I have wasted weeks on this already.
Have you scaned for Bad frames?
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
when you convert with TMPG, do you do audio at the same time, or do you do audio separate, and multiplex later (recommended--BBMpeg to mux)
did you downsample to 44.1khz?
I would recommend doing audio separately using BeSweet, and then video only with TMPG, then BBMpeg to mux--should work like a charmwhat are you askin' me for...
I'm an idiot! -
If they play correctly on the computer but have sync problems on the set-top player, it might just not like your media. Computer CD readers are more tolerant than many set-top DVD players. Have you tried using a few different types?
Some DVD players just work better with CD-Rs from certain manufacturers, you might check the comments on your player in the compatibility list to see if anybody else has said that certain brands do or don't work correctly.
Audio Sync issue?
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 11:25 -
Audio sync issue
By Nightshiver in forum AudioReplies: 10Last Post: 2nd May 2008, 18:37 -
Audio sync issue even when dynamically resampling audio
By purpleman in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2008, 10:18 -
Audio sync issue with
By 123fish123 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2007, 17:54 -
Audio out of Sync Issue.
By DSMKilla in forum Capturing and VCRReplies: 7Last Post: 17th May 2007, 00:27
