  1. hi all
    i am having trouble with tmpeng i convert my mpeg into audio and movie file the guide says change the extension of the audio to mpa do you just do this by renaming it. i have authored the file with spruce and get everything write but just cant suss the audio
    thanks in advance
    Mar 2002
    chicago
    Originally Posted by ericthegreat
    hi all
    thanks in advance
    I'm assuming that you're audio file is .mp2, in which case, you can just rename to .mpa
    if that's not the case, please provide more info.
    also, try to use a more informative subject for your posts
    what are you askin' me for...
    I'm an idiot!
  3. yes m8
    use simple de multiplex on tmpeng it then splits the mpeg to 2 files
    however they both say mpeg movie files the smaller one is obviously the audio i then right click the smaller file and rename to .mpa i then give both files the same first name and stick them in the same folder then use spruce everything seems ok but just cant get any sound
    cheers
