After using Spruce up it converts my 16:9 movie into 4.3, is there a way to convert in back to 16:9 without losing my Aurthored film.
You can use an IFO editor (like IfoEdit) to edit the movies IFO file to change the aspect ratio from 4:3 to 16:9.
On you finished movie, use IFOEdit to open the main movie’s IFO. At the root of your IFO you should see “Title Set (Movie) attributes:”. Double click “Video: MPEG-2 720x480.......” to open the video attributes. In the “Aspect Ratio” box check “16:9”.
D -
sorry about this, after that do you just untick the boxes and do vob extras?
