  1. ok i have ripped the dvd to hard drive its now 5.3 gig
    what i need to know what sw to use to reduce these files
    have all the sw but wat order to use them have no problem coping I have coppied from satellite and burnt to dvd excellent quality (mpeg 2)
    using tmpeg dvd2avi ect
    but now trying to get a dvd to dvd just need to know how to reduce the file size just say the sw and what order I will sort the rest
    sorry if this has been asked b4 but have got confuzed with all the info
    thank KAce
    Long Beach, CA
    I find that tmpgenc allows you to vary the bitrate, and thus control the final filesize.
    If you have the ripped DVD files in a folder, TMPGENC will work.
    For best results (but much slower), I use 2-pass, with the AVERAGE bitrate set, so it fits on 1 DVD-R, and the bottom bitrate set to 2000 and the top to 7000.
    Let me know if you need more clarification.
    P
    My system:
    Abit Ic7G
    P4 3.0C @ 3.98 GHz
    2x512 MB DDR 500 ram
    WinXP Pro
    ATI Radeon X800pro
    5x120 GB Western Digital ata100
    TDK Velocd 48x16x44
    Sony 8x DVD burner
  3. thank s M8 will let you know
    doyou have to do each file seperate just a thought
    KAce
  4. First when Ripping it leave Angle1 on only.
    Using IfOedit, you could strip out audio/subtitles you do not need.
    Maybe you could get it down to 4.6GB
    Look at this part that was posted: Aug 26 16:10
    http://www.vcdhelp.com/forum/viewtopic.php?t=109346
    Long Beach, CA
    You don't need to do every file separately, nor do you have to strip out stuff, if you RIP the DVD with CLAD.
    CLAD has its own demuxing tool (DVD2AVI) built in, and will create a file which can be processed by TMPGENC, which in turn will allow you to regulate the output size.
    Good luck
    My system:
    Abit Ic7G
    P4 3.0C @ 3.98 GHz
    WinXP Pro
    ATI Radeon X800pro
    TDK Velocd 48x16x44
    Sony 8x DVD burner
