I would like to know if you can cut a mpg2 that's already encoded into 2 pieces like you can do with avi files in Vdub. cus i like to encode the entire movie, and i dont' have a DVD Write, so i have to split the movies to fit on 2 or 3 CDs. thanks for any help.
There are number of tools for this, starting from TMPGenc. Womble is better and faster. Any mpeg editor, which doesn't reencoden everything, will do.
are there free ones that can do the job. i really appericiate it. cus the main problem is when i split the avi with vbr audio files it usually gives me audio sync problem on the 2nd half of the movie. so taht's y i want some thing that would cut mpg2 files. thanks
bbmpeg and tmpgenc are both freely available and can cut MPEG2 files. I've sometimes gotten sync problems using them, but others say they always have good results. I think both are listed under the "Tools" section on this site, and both have how-to guides under "Edit".
If you're encoding AVI files to SVCD or DVD and want to cut the movie in to multiple files (ie span 2-3 CDs), your best method is probably to use the tmpgenc "source range" filter (or the equivalent in whatever encoder you use) to just encode the portion you want. And if you have VBR audio, extract it to a WAV file with VirtualDub and use that for the audio source instead of getting both from the AVI file. -
Never heard of Womble. I assume that you need to purchase it.
Please tell me something about it.
Thanks,
Jon -
This one works great..
http://www.digital-digest.com/dvd/downloads/mpegtool.html"Today is only yesterdays tomorrow"
Edit/cut MPEG2 TS
By jon222 in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2014, 15:30 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
Cut-Edit Converted FLV download?
By ranchhand in forum Video Streaming DownloadingReplies: 4Last Post: 15th Aug 2010, 09:33 -
Is there a way to edit (cut) an iTunes DRM video file?
By jimdagys in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2008, 08:05 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 15:55
