i've got a pioneer dv333 and it has been great. it plays everything flawlessly, but i am now having trouble with the disc tray. i'll press the open button and the tray will open.. but then close immediately after opening. i can try to put the disc in really fast, but i'm not sure why it won't stay open. if i keep pressing the open button eventually it stays open, but i'm not sure what's wrong with it. has anyone else experienced this with the dv333 or any other player? should i open her up and see what might be going on inside? any ideas out there? thanks.
does it exhibit the same behavior if you open the tray using the remote?
TRY TO OPEN WITHOUT THE CONTROL AS THE REMOTE COULD BE THE PROBLEM BY SENDING OTHER SIGNALS AS CLOSING THE TRAY
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 17th Feb 2012, 00:54 -
Harman Kardon DVD-22 won't open the disc tray
By edong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th May 2011, 17:11 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 17:39 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 12:41 -
liteon disc tray will not open
By northy44 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Sep 2007, 08:20
