i want to capture with HUFFYUV codec. my capture card does not allow this
which affordable card (< $200) can do the trick and produce good quality
output?
thanks
rene
i have a FAST AV Master which has a hardware MJPEG codec on board
it does not capture without its own driver
ahhh - unfortunatley you have one of the ohh about 3 cards on the market with that problem - I have a DC30 with a similar problem.
I suggest you look for a cheap , cheap Brooktree based TV tuner card
there are literally hundreds on the market world wide.
Try really really hard to get a brooktree (Conexant) based card as this will give you less problems.
you can probably get them for around $30-40 in most places
The results can be very good - esp with Hufy as you wanted
but a hardware mjpeg card is alot easier to use - unless you have the same problem I did of no XP drivers for the DC-30 -
i appreciate your advice a lot
my av master also has no drivers for xp but i use dualboot and capture in win98
has the quality (price) of the tv card no influence on the capture quality?
and can you name a card you would advice?
thanks again -
Well not really - as I said above - only get something with a Brooktree (conexant) based chipset on it and you will be OK
they usually list the model of the chip on the back of the box
the lastest chips are BT879/878/848 and similar
these cards all use the same design and take the same modified XP drivers
you should avoid using cards that don't specifily list a brooktree chipset as most of the others use a philips SAA***** chip and this causes problems - lots of problems if fact with XP you can almost forget getting a decnet capture at all.
hope this helps - if you want more info mail me
Alternative to HuffYUV for VHS capture.. Need smaller file sizes
By HDClown in forum Capturing and VCRReplies: 19Last Post: 16th Sep 2011, 15:48 -
Capture YUV with HuffYUV
By smartel in forum Newbie / General discussionsReplies: 12Last Post: 31st Dec 2010, 09:21 -
Which of these TV-cards capture analog to AVI, using Huffyuv or M-JPEG,...
By dOdGE dIZ in forum Capturing and VCRReplies: 15Last Post: 9th Mar 2008, 09:01 -
Proper way to capture in Huffyuv?
By CCEncoder in forum Capturing and VCRReplies: 4Last Post: 10th May 2007, 07:52 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
