  1. Heyyy
    Why is it, that my burned Vcd won't run probberly, when i use my DVD'player.
    I burned it with Nero5599, and it is 352x288 25fps, and 44100Hz stereo
    It's burned with 8speed on a Plextor 16x
    It will only play i small breaks
    I've had this prob. several times
  2. What brand DVD player do you have? Have you tested burning
    a VCD with VCDEasy? What media did you use? - have you
    tried using CDRW media?
  3. My DVD Player is a Phillips DVD723
    I've tryed diffrent brands of media, but nothing appears to work, i'va rtied burning. like 4 times, on diff. media, with diff. speed.
    I've tried burning with Roxio, and Roxio wont recognice the movie as a Vcd format, but NERO says it is........Cofused, I am.......
  4. The problem is with your Phillips DVD723. Try CD-RW instead of CDR media.
  5. you may want to try and remove the menu of the VCD. FOr some odd reason my DVD player wont get past the menu even though PBC is enabled . i hope this helps you out!!
