I want to know when you use TV out with a video card can you record to a VHS from your computer and does it look as good as it does on your computer? Thank you
If you are talking about outputting recorded video, then the video out to the TV actually looks a bit better in my opinion because the computer monitor tends to be sharper so blockiness is reduced from how it looks on the computer.
If you are talking about displaying stuff you would normally view on a computer like windows programs, web browsers, etc. The TV output is fuzzy compared to the video monitor.
Yes, you should be able to record the output to a VCR. The recorded image will of course not be as good as what you view real time simply because the analog process loses quality.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
