Hi,
How do you reencode a DivX movie to Mpeg keeping the aspect ratio.
i.e. when I watch the movie in Realplayer it is widescreen without any borders, but once I've encoded it, it streches the film to 4:3 which looks crap.
Also what is the maximium screen size for VCD and SVCD
Thanks in advance
Mark
First Load the divx file into Tmpg. Now choose your prefered output format ( Vcd, Svcd, etc. ). Klick on the button settings here switch to advanced. And select 1:1 VGA and Full screen ( keep aspect ratio ).
This should work . -
Try this:
After you've chosen your template go to settings.
Under video, klick on Aspect ratio, and choose unlock. Now you can select 16:9 Display.
Under Advanced, make sure aspect video source is set to
1:1 (VGA), or the respective 16:9 setting (pal or ntsc).
Under video arrange method select Full Screen (keep aspect ratio)
This should solve your problem.
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 04:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 09:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 04:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 19:59
