i often use tscv for creating menu and it save s all the bmp as a bmp called seq-xxxxx, depending on the number of the file it is.
For some reason TMPGEnc wont encode these file into an MPEG, does anyone know why? It says file format unsupported, even though ive seen it do it before when TSCV would just give me black screens where the video should be in the menu. After many moons, i finally got TSCV to produce the menus properly, the process goes good and TMPGEnc opens then KABAM it tells me unsupported file format.
My computer is at risk of being burnt/destroyed becuase i am really knarked off about it. and i also risk going bald at 18.
Can anyone help?
btw I cant use TSCV with avi2mpg because in the log TSCV comes up and says "c:/program not found" whenever i use that option for menus instead of TMPGEnc
Anyway, many thanks in advance
Craig
i dont know that program -so hence exactly the type of bmp it is producing - but an easy way to fix it would be to mass convert them with either ACDSee or paint shop pro - which will, in-mass, convert your sequenced files to compressed targa's or you can also use jpeg's with quality set to 100
many thanks for the reply, does tmpgenc recognize a targa file and what is one?
yes tmpgenc will use targa files no problems except prev to version 2.54 , it would not use compressed targa's (lossless) but it does now use either compressed or uncompressed ..
targa along with sgi and cineon (and tiff to some extent) files are all very high quality file types used in the movie and graphics industry..
recording 3D field sequential ntsc signal to PC
By shpitz in forum Capturing and VCRReplies: 14Last Post: 22nd Sep 2011, 12:30 -
Field Sequential movies 3D stereoscopic
By erbipjr in forum Off topicReplies: 1Last Post: 6th Oct 2009, 15:56 -
ConvertXToDVD sequential playback
By stantheman1976 in forum Video ConversionReplies: 6Last Post: 26th Oct 2008, 22:44 -
converting sequential frame to FLV
By tais in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 09:49 -
Question About PhotoSharing Websites and Sequential Order.....
By RKelly in forum ComputerReplies: 0Last Post: 10th Jul 2007, 00:17
