I was wondering if TMPGenc goes past the 2 pass VBR ? Or is there something i can do to get 3, 4, 5 , or even 9 pass VBR ? Or should i buy CCE to get this kind of VBR passes ? What is all of your expert opinions ?
TMPGEnc only does up to 2pass.
CCE can do more.
If you set the settings right, you really don't need to go above 2-ass (whoops!) 2pass.
1 pass is to analyze, 2nd is to encode. Any more is just comparing the "error" or difference between that encode vs. the original, and adding a few coefficients to minimize this difference. It's one of those Entropy/Hyperbolic function things, which will provide diminishing returns with successive passes.
A slight change in the bitrate or matrix probably makes as much difference. (Ooh, that sounds like flame material!).
Look at what the Heavy-duty hardware encoders do (Zapex, Sony, Spruce, etc). 2-pass is the max. They just do segment re-encoding to fine-tune the bitrate on particular sections of the video.
If you're careful with quality source material (uncompressed 601, DV, or maybe even high-bitrate DVD), and with judicious use of pre-filtering, a 2-pass encode should be all that you need. But don't just take my word for it--do lots of tests with DVD-R/W's and CD-R/W's (ok, +R/W's too) What have you got to lose-you don't need to encode 2 hours worth. Just try 30 seconds here, 2 minutes there. And you can always erase your coasters and start again. Then you could impart your knowledge and experience onto the rest of this group.
Happy encoding!
Scott -
Well said Cornucopia,
Much appreciated advice. But what is better to encode in 2 pass VBR, TMPGenc or CCE ? Right now i use TMPGenc, but is CCE better or faster ?
I have not used CCE at all, but i have heard some excellent things about it. Are they all true or is it someones figment of imagination ? -
you can get excellent results with either of them .. CCE is faster though ..
A lot of people feel CCE is better - but doesnt do so good at lower bit rates ...
The biggest single factor is source materal and bit rate .. well thats two factors .. -
Yes, there are diminishing returns with additional passes, but 2-pass is not the be all and end all. Certainly 2-pass makes a big difference over any 1-pass method and the yield from doing 3-pass is not as great. However, you will see benefits doing doing additional passes if you are willing to make the time/processing commitment.
Regards.Michael Tam
w: Morsels of Evidence
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2009, 23:49 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16
