  1. Hi,
    I have a Sony DAV S300 DVD player. This system works fine with original VCDs & DVDs. But when I try to run pirated VCDs, only some work! When I copy the contents of the same pirated VCD onto a CD-RW, it works perfectly fine. On the other hand, when I copy the contents of the pirated VCD onto a CD-R, the system does not recognize it.
    My question is, why does my system recognize only some pirated CDs? Also why & how does it work when the same contents are copied onto a CD-RW & not to a CD-R? Am I missing some step in the copying process?
    I use a LG CD-Writer with Nero 5.5 to copy my CDs.
    Please help.
    Regards,
    Lissy
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    It may very well be that your DVD doesn't support CD-R & CD-RW, even if it handles VCD. My experience is that a CD-RW is more "compatible" with factory manyfactured CD's than CD-R's, so that may explain why CD-RW's work. Or it may even be that the DVD actually support CD-RW but not CD-R, even if that sounds unlikely. CD-R and CR-RW uses different laser wavelengths (or something like that).
    /Mats
  3. For DVD drives that weren't designed to read CD-R or CD-RW media (e.g., many older Sony DVD models), it just so happens that the laser system on the DVD is relatively more compatible with CD-RW discs rather than CD-R. This is why for such drives, it has been common reported that CD-RW discs work better.
    Regards.
    Michael Tam
    w: Morsels of Evidence
