Hi All,
I am using DVD2AVI, to setup for TEMPENC the dvd is 16:9 but when I convert it, it is full sceen, not letterbox.
When I place into TEMPENC and try to convert to MPEG it is still FULL SCREEN.
How do I get Letterbox effect in TEMPENC as I have gone into setup and have changed it to 16:9 which is letterbox BUT still comes out fullscreen.
Thanx
HOBMOB
In the "Video" tab pick "4:3 Display" for "Aspect Ratio.
In the "Advance" tab pick "16:9 display" for "Source Aspect Ratio". And for "Video Arrange Method" pick "Full Screen (Keep Aspect Ratio)" or "Full Screen (Keep Aspect Ratio 2)".
-LeeBear -
Can someone tell me the difference of using the 4:3 display compared to the 4:3 NTSC display option in TMPGEnc. I always use the 4:3 or 16:9 NTSC display when I encode from NTSC DVD's but have seen that a lot of people simply use the "display" only settings.
Try this
Source aspect Ratio = 16:9 (NTSC or PAL)
Image Positioning Method = Full Screen (keep aspect ratio) or Fit to frame ( perserve aspect ratio) for old version.
To scottremel. I sometime use 4:3 display only when I convert from avi with 4:3 type of resolution such as 320x240 and use 16:9 display with wide screen type avi movie (most of the time I use 1:1).
If you rip from NTSC DVD, you'd better go with 4:3 NTSC or 16:9 NTSC which will give you the right aspect ratio than 4:3, 16:9 display. -
can't assume that widescreen is 16:9, there are nonanamorphic widescreen that is 4:3Originally Posted by LeeBear
Premier CS4 and letterboxing?
By beavereater in forum EditingReplies: 2Last Post: 28th Dec 2009, 22:42 -
Convert 16:9 to 16:10 with letterboxing hardware
By JesterMania in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Dec 2009, 15:29 -
Letterboxing video for youtube
By cwy in forum Video ConversionReplies: 5Last Post: 2nd May 2008, 09:35 -
Beginners guide to letterboxing on a PSP
By pollus in forum ffmpegX general discussionReplies: 0Last Post: 20th May 2007, 03:15 -
removing letterboxing on MPEG2 files
By hellsaviour in forum MacReplies: 3Last Post: 13th May 2007, 15:17
